By Tea_Bag
#274637
Hi
I'm looking for a good electrical circiut board kit thats straight off the shelf do you guys know any suppliers website in the uk that offer ready made kits?
Im looking for this type of circuit
Input Power requirement (circuit board)
• 240VAC/50Hz
Output Loading
• Line Input: 240VAC/50Hz (Max loading 3120W)
• 3 Relay outputs 7A@240VAC
• 2 variable SCR control outputs
Each output supports up to 100 Watts
Thanks
By mtripoli
#274671
I think you can use solid state relays for what you're looking for. I don't know if you have anything like DigiKey (www.digikey.com). Here's a link:
http://search.digikey.com/scripts/DkSea ... 46-1041-ND
These are DIN rail mount so they're pretty flexible.
As for the "variable SCR output". Sounds like you're looking for light dimmers... any hardware store should do you....
