By jvanmetre
#274405
I'm working with some MXMs where I've added a BSDF layer and when I try to export using Pack & Go -- they do not export.
As a work around, I saved the file using "Save As" and when I open in studio, the material is present, but when I try to save it again for rendering, when I open in mxcl, the render stops at the material -- even though it is assigned.
It seems there is an issue with altered MXMs and exporting.
Using 1.7 for XP (32 bit)
jvm
By jvanmetre
#274412
I've also had instances of materials in which I've turned off (unchecked) a displacement map before exporting and I later find that it has turned itself back on.
It's all a bit too mysterious.
These same MXMs could be tweaked without a problem under 1.6 and 1.6.8.
jvm
What happens if you render it from Studio, pressing the render button that opens MXCL? If you can please send me a scene that doesn't render.
