- Wed Jun 25, 2008 4:53 am
#273835
If I load a high poly tree in Lightwave and clone it 1000 times in layout then check use instance in the Maxwell that the proper way to use? If I export to Studio just the original is there and all is fine. But if I render in Lightwave plugin all that extra overhead of the actual 1000 trees in Layout is still there. Would it not be better to just have a null be linked for instance placment, or better yet points that a plugin could detect? Maybe I am just using this wrong?
- By Matteo Villa
