By trofaster
#273794
Hi
I'm getting black spots in a simple render with just a very few pieces of geometry and an hdr-enviroment. There's one SSS material in the scene.
Here are to examples, rendered to sl 17-18
and
Scene can be found here:
http://www.dimension3.dk/transfer/black_spot.zip
I'm running max9, win32 on 2GB RAM dual Core AMD.
By trofaster
#273904
ping.....
Anybody there?
By choo-chee
#274708
I get the same black dots all over my render ! and textures are not displayed at all ! (with the "NEW" physical sky) ... !!!! is there any quick fix for it or I'm gonna go back to 1.6 ?!?!?!
By choo-chee
#274712
I think materials with SSS are crapping the render. I removed the trees and the grass and it looks better. instead of tons of black dots and strange blue areas I get my scene back. BBBBIIIIGGGG BBBBBUUUUGGGG !!!!
By ishook
#276418
I'm having issues with black dots whenever I have an MXI emitter used. I have to change it to a normal emitter to get rid of what my team is now calling flies. Somtimes they swarm, especially around SSS objects. The odd thing is that they appear more and more as the render continues. A perfect patch of pixels can render up and 10 minutes later there are flies where there was once normal pixels.
Shook
By sidenimjay
#276426
i have seen some posts that seem to suggest that if an object is not closed when using sss it will produce these nasty little flies....
the more open objects the more flies....
thats what i have noted anyway
This bug is confirmed and fixed in the next update. :wink:
By ishook
#276433
Thats pretty fly.
By opm
#276899
This problem is solved already ?
Here, my example:
It is made in C4D 10.5
render directly from C4D witch plugin Cinemaxwell_1.7
SL is 19.26
there is no sss material
no ags (window is empty)
sorry for my english!
Greetings
By ishook
#276921
No silly, the NEXT update.
:wink:
By opm
#276936
Understand already and apologize ;)
I wait patient.
Greetings
By AndreD
#277069
count me in ;-)
no sss / no ags
By ishook
#277106
no sss / no ags
What about MXI?
This has been fixed, could you please confirm?
