- Tue Jun 10, 2008 6:08 pm
#272192
Hi, does anyone know if there is a limit to how many faces or features can have different materials assigned to them?
The reason I ask is that I've part working with a fairly large and complex part (lots of curves & faces, takes forever to rebuild) which has different textures in different areas. I'm achieving the difference in textures by simply assigning different materials to the faces (I assign one to the body as a whole, then assign a second or third to indiviual features or faces).
This works for a while, but after a certain point I can no longer assign materials to features or faces. I highlight a feature or face, right click on the material and choose "apply to selected." But when I reselect the feature or face it only lists the body material assignment in the properties window, and if I render it my non-assignment problem is confirmed.
I thought I had fixed this by Enabling Viewport Materials (after I found the button, it sits there so nonchalantly) because the faces changed textures when I thought I assigned materials, but still the faces did not actually change materials. And then I was left with a part that had a mess of SW texture assignments that incorrectly reflected the Maxwell material assignments.
Has anyone else experienced this problem and found a fix?
[P.S. - I have been able to work around this for one render by splitting the part into multiple bodies for large sections of different texture and making sure to do face assignments on the more complex section first before it stops working, but this is definitely a band-aid and not a full fix]
- By Mark Bell
- By Edward Leibnitz
