- is literally the same thing that Save As does.I can set the path in the scene manager and do 'export MXS file'
Should I assume when you say 'doesn't work' that you are or are not also experiencing some type of crash, as Will reported? If/When not, when it is finished exporting, where does the Log Viewer say that it wrote the MXS file to? Is it a regular local path? I mean, are there any issues with network, or since you're on Vista, do you have permission to write files to the target location?Eric Lagman wrote:It doesnt work here either. I see it processing the scene in my task manager, but when I go to look for the file its not there. I searched my whole computer for the file and can only find a shortcut with the filename I gave it to save the mxs as.
I did not recall this being an issue, there was previously one where the Render Settings page wasn't saved, but this was fixed. Just because I have to ask - you say 'close sw and reopen' - are you also saving the document?Eric Lagman wrote:On another note. My scene and image path output path in scene manager is still not being saved when I close sw and reopen.
That is what it is supposed to do. I think the problem you are referring to was one where SW cameras which had been deleted were still exported.Eric Lagman wrote:Also the standard views top back front are getting exported to the mxs file. I thought this was fixed.
I am using it right now on M1 Max and latest macOS[…]
