By deadalvs
#269499
hi !
is there a free and simple to install linux 64 bit distribution available ? which one ?
do the different distos influence render speed ?
i am thinking about future renderslaves running on linux.
By Rickyx
#269542
deadalvs wrote:hi !
I'm Ubuntist so I suggest you Ubuntu, for 32 and 64bit Intel processors.
Download the brand new release "8.04 LongTermSupport" -codename "Hardy Heron"- Desktop or Server version from:
http://www.ubuntu.com/ ---> http://releases.ubuntu.com/8.04/
Quickest way to download is torrent.
Very easy to install.
I think performances on different distros depends a lot from the kernel (compiled or not) and from the number of active services.
By deadalvs
#269543
thanks for this info ! downloading ...
i checked www.benchwell.com ..
there are nearly no linuxes around.
have you tried a direct comparison between windows and ubuntu on one machine... ? was there a significant time difference ?
how stable is ubuntu compared to win xp64 ?
By Rickyx
#269568
Ciao deadalvs,
unfortunatly I do not have any Win64 -Wx nor Vista- so I can't comparate between the two.
And obviousy I see positive differences between 32 and 64 bit...
Ubuntu has not significant stability issues that can diminish user experience, is ultrasecure while browsing the web and solid as server...
:wink:
Ricky
Ps: BUT if your primary target is stability than choose Debian ( http://www.debian.org/ ): even if Ubuntu is based on Debian, it has "non ultrasecure packages" coming with.
By deadalvs
#269633
ah that sounds great... especially for a free OS !!
i will think about this ... :)
thanks !
By codygo
#269647
I run gentoo compiled for opteron processors and 64 bits and performance is slightly lower than in xp pro 64. Still cool though, I would be more comfortable using ssh to transfer files to my linux computer at home and using command line to render them than alternatives in windows.
By deadalvs
#269754
i have an other question.
renderfarming is and endless fight with cashflow ... :)
i'm still thinking of some sort of low-cost cluster. so for each slave, even the cd/dvd rom is not a must since the slaves are there just for rendering purposes.
is there an easy way on linux to install the complete OS on each slave from a network directory with the full installer (like that ubuntu.iso) ? and for other software like maxwell, is it also possible to admin that just over tcp/ip with multiple slaves at once ?
By pwrdesign
#269764
Just make a Clone/ghost!
I've got a clone set up on a server here at work, when I have a new render-machine/or need to reinstall one, I just boot on the disk, point to the server and the server is restored. It takes about 10 minutes, all I have to do when its done is changing the IP number back to the one it used to have. (we are using static IP's here)
By deadalvs
#269765
sweet ...
i bet that saves a looot of time !
By deadalvs
#269768
how do you guys deal with different hardware that need different drivers and a single OS images can't handle all slaves ?
By pwrdesign
#269769
Yes it does!
Im using clonezilla
I've got two different hardware setups in my farm, and I have to make two clones. It takes about 10 min to do a clone though so its not alot of work.
