- Fri May 09, 2008 5:43 pm
#269021
Firstly i must say that the 2008 plugin is so much better than the initial one. I can actually render stuff directly from solidworks now! Thanks to all the hardwork of the people involved.
I do have some questions though!
-Is it possible to apply materials to an object in an assembly without the material being applied to all instances of that part in the assembly?
-Is there a similar command to autofocus in solidworks. or how do you set the focus without using studio?
-if the photoworks plugin can manipulate textures why cant the maxwell programmers have access to those same controls?
-If a feature for moving textures was really not available in solid works i would be very happy with a randomise feature. This would randomly change the offset of the texture when applied to different parts. This would avoid bad tiling accross parts. A tickbox would do!!
cheers
cheers
- By Mark Bell
