By Gary
#266928
I have run some simple tests with form z cone and form z custom lights to mxcl and nothing works. with multi light on, I can see the light, but no light is emitted in the scene. With multi light off, also no light emitted.
Any ideas?
Gary
By juan
#267014
Hi Gary,
I suggest you to open the scene in Studio so you can check if the light material has the intensity too low, or if there is a problem with the normal vectors or the light location, if you can see the light, then it is sure it is litting the scene and its just a matter of increase its power..
About if the light is visible or not, there is a preference in the Maxwell options in the plugin "Hide to camera exported lights", maybe its enabled, and in that case you won't see the light. This option is useful when you want a light to lit the scene without being visible.
Regards,
Juan
