By Torviz
#266867
When I try to drag & drop a forming tool over a sheet metal part when the Maxwell plugin is active (loaded) I get a icon (circle with a diagonal bar) saying that I can't perform the operation. I need to unload the Maxwell Plugin fot it to work.
Maxwell Plugin 1.6.6.0 x86
Solidworks 2008 SP 3.1
Always did that with Solidworks 2008
Daniel
#266962
Hi Daniel,
Yes, I've not yet been able to determine the cause of this conflict - the plugin is not doing anything special in the case of forming tools. It's strange, because it only occurs when dragging objects as forming tools - if you also set the folder to show assemblies, you can drag those, and if you disable the forming tools toggle, you can drag parts.
JD
I am using it right now on M1 Max and latest macOS[…]
