I'd check the resulting material in Studio to see if there isn't anything wrong with the conversion. If you want you can export and post the mxm.
By mojo
#266164
this kind of conversion seems to happen to all my pretextured vegetation models (like onyx or vbvisual ... ) when trying to export directly from the plugin
Looks like the problem is the layers become reversed - the lambert one should get the texture, and the roughness 0 one should just be the reflective layer.
By mojo
#266170
is there a trick to avoid this bug,
maybe by changing the setting in formz to make it lambert or at least high roughness in formz ?
i dont want to create thousands of mxms for alle the vegetation i need ..
By mojo
#266289
ok. sorry for this thread. i've noticed that there wasn't the latest plugin in my maxwellz folder..... now it works again. :oops: :oops: :oops:
