By lonn
#264625
When I have 100 emitter in the scene, how can I group them into small group. Let's say 10 emitter i= one group. The problem I am having is Multilight function crowded with 100 emitters. I just want to have a few group in Multilight, so that it is easy to change the lighting without controlling all 100 emitter at the same time.
In 3DSMAX, I would attached the light emiiter into one object to create group. However, in Rhino,
the group function doesn't group emitter
instance doesn't work with emitter
"block" command would help grouping emitter
#264627
To do this in Rhino, create your emitter objects as meshes (not nurbs), then use the Rhino Join command to put your groups together. It's better to use meshes for emitters anyway, so you have more convenient control over how many polys they have.
