#264401
Hello
After MXCL finishes rendering, when i adjust the lighting and hit refresh. The image on the screen updates but I cannot save the image. Infact, all of the options to save, load, etc under file are grayed out. Any help would be appreciated as I have a deadline today.
Thank you
Jason
That's strange, there should be an mxi saved automatically when rendering. You can check in the Render Options tab in MXCL where it's saved. You can then load this mxi in MXCL and save out any image formats you want.
#264422
I've never heard of this happening - are you sure it wasn't still rendering? They should be greyed-out only if it's currently rendering. Also, you'll probably get more/better answers posting general non-plugin-related questions in the main Maxwell Render forum.
JD
By VALKAMA
#264440
Thanks everyone for the response. MXCL was finished rendering but still all of the buttons were grayed out? This is the first time this has happened. I was able to get around it by resuming the rendering, changing the lighting settings, then waiting for it to update the image.
So it worked for this deadline.
Thanks
jason
