#263484
It's still being tested.
As far as helping you to avoid the use of Studio, the most important improvement is support for the native SW texture 'rotation' parameter. So in cases where you would currently need to physically rotate a bitmap file (and then, you're restricted to 0-90-180-270 rotations) you will be able to use the native SW rotation control. By SW rotation control, I mean, the one you get for an object when you right-click > Appearance > Texture > FeatureManager > Texture Properties - although Maxwell has no rotation parameter available, the plugin will modify the object's UVs on-the-fly to match this rotation. So, if you can acheive an acceptable mapping that way, you won't need to use Studio - if you need more complex projection-type mappings, you will. The new plugin will also optionally generate multi-materials for objects which have no Maxwell Material assigned - currently, only component and body level native SW materials are considered during export.
For a timeline...well, as soon as possible is all I'll say.
JD
#263568
Currently, no. As I said, since Maxwell doesn't have a rotation parameter, the plugin has to get that information from SW and use it to modify the UVs for every mesh triangle during export. The current plugin cannot do this (not on SW2007 or SW2008) but the next version can.
what about gpu maxwell q project?
SS Pinto Bean
Hi Tommy, Great stuff - love it~! Thanks for pos[…]
Never No More Studio Lighting
Hello Mark! Very good tips about the camera setti[…]
