By pluMmet
#25450
Well I must say that I love this renderer! It need more shaders and has some problems but that's to be expected at this stage ;)
So here's what I have: (I know it need more detail but it's a start.)
Image[/img]
This is a cute scene :D
It needs a little more light though. Its kinda dark right now.
By pluMmet
#28141
Well here's an update:
I did a little post on the glass in PS...I also rendered in other renderers...man they S*&K compaired to M~R :)
By macray
#28484
For me it's still way to dark. The model is nice, but the picture looks empty.
By pluMmet
#28587
I'll lighten it up some more :)
As far as it being empty....? I'd like to add something but I'm a bit of a minimalist and like open spaces. I'm trying to think what to add while keeping it expansive?
Hiya!
This is a nice start and i got a few pointers for u if u don't mind, this i just say so u can improve it further if you want to and make something that might even appear in the gallery if you're lucky ;)
My suggestions..
- Change the camera angle, maybe slightly up above looking down on your scene.
- Add caustics.
- Adjust the light setup, maybe make it more into a studio light setup for this.
- Find new textures for the floor and background
- A faint bumpmap adding small scratches and tiny dents to the objects make them more realistic.
- Play a little with DOF and see what it can do for your scene, blurring the back wall brings your models in focus.
- If u use Zbrush 2 then u can detail the dents and bumps to boost the realism even more.
- I can't quite make out the background behind your glass figures but if it's a wall then plz make it look like a wall.
- As the other said the whole scene is too dark, boost the intensity and make it more interesting with multiple lights as i also said earlier in this post about a studio like setup, then u should get caustics automatically and a set of nice shadows u can play with.
Keep up the good work!
By pluMmet
#28664
Thanks for the support Max, I'm giving it another go!
By pluMmet
#29008
Revision:
no post processing :)
By pluMmet
#29143
Sgög? wrote:The emitter would be better ANYWHERE else than directly behing the camera ;)
lol. O.k. Thanks!
By pluMmet
#29176
Here's the latest (the cooperative render for some reason only merged 2 of my 4 computers for this image. The other 2 finished sucessfully but the manager and monitor don't seem to know it.) :
Unfortunately the 2 that hung up reached level 14 while the 2 that merged reached level 7 so this is a dual level 7 image hence the noise on the wall :?
let me know what else can be done :)
By macray
#29190
Thats a lot better. With the light at the glass and the nice small reflecions on the little ones the only thing I see is some reflections and bumps in the ground floor missing.
By pluMmet
#29197
Thanks macray- I don't know how to get the floor to reflect...it's a diffuse shader and there is no way to do it that I can see! I have seen others get floors reflecting. How is it done?
By pluMmet
#29202
actually I tried to reflect before and it didn't work I think because of where the light source was. I'll try again. Thanks!
By pluMmet
#29224
There is no spinner in Max for the color channel...reflect is set to 1 (and I tried .8 ) and no reflection. So how do you get it to reflect?
