- Tue Mar 04, 2008 5:52 am
#262928
RhinoScript loaded.
Loading Rhino Render, version 1.00, Oct 17 2007, 11:04:16
Loading Maxwell for Rhino 4, version 1.6.1.0, 9/12/2007 22:52:56
Maxwell: The Maxwell for Rhino 4 plugin does not contain any direct rendering functionality,
and therefore requires that Maxwell Render 1.5 or greater to be installed on this machine.
Maxwell: If you have already installed Maxwell Render 1.5, it is likely that the installation did not complete sucessfully, or has become corrupted.
If this is the case, please use
Maxwell: Add/Remove Programs to uninstall the program, before reinstalling. If you continue to receive this error after installation/reinstallation, please contact Next Limit support.
Command: _SetCurrentRenderPlugin
Plug-in name or ID ( Rhinoceros ): XXX
Current render plug-in set to "Maxwell for Rhino 4"
Maxwell:
Bumped into this error message today, not sure has it been here that I just failed to notice it or not... However besides this, I have had another problem that maybe related.
I found that my scene manager / location settings & environment setting having bugs which were supposed to be fixed in 1.6.X, including strange location setting bug & mutiplied offset UV values. turned out that its not fixed on my 1.6.1
Does it mean I have a faulty 1.6.1 installation that still running as 1.5.x?
Thanks and best regards
Jacky Lok
Maxwell:
Jacky Lok
