You might want to check out Richard Rosenman's DOF Pro Generator plugin which might help if used in conjuntion with Maxwell Render.
http://www.richardrosenman.com/dofpro.htm
Tyrone,Tyrone Marshall wrote:You might want to check out Richard Rosenman's DOF Pro Generator plugin which might help if used in conjuntion with Maxwell Render.
