By Matthias Wirth
#260060
Hi
gives good tutorial link for displacement in the web
wich software is the best for handling displacement
Thx
Matthias
By Matthias Wirth
#260115
Hi Nicole
thank you for you help
matthias
By Matthias Wirth
#260121
hi Maximus3D
wau super good thanks for the tipp
is that the programm do you use for the super mxm,s ?
Matthias ;-)
By Matthias Wirth
#260125
Aha Maximus
i look at FilterForge, Gimp and Texture Maker, MapZone.
by the way
your materials looks allways very good ;-)
Matthias
Many thanks Matthias, i appreciate your kind words :oops:
Here's some plugins you might find useful for Gimp :) they're easy to install
http://gimp-texturize.sourceforge.net/
http://www.logarithmic.net/pfh/resynthesizer
http://liquidrescale.wikidot.com/
One more thing about Gimp on Windows, sometimes on some systems with alot of fonts in them you may get a crash when you startup Gimp as it has to cache all fonts. However to get around that problem you can disable all font loading. Then you will obviously have no access to any fonts within Gimp but atleast it'll run.
The solution is to select properties on the Gimp shortcut icon, and in the Target path you add after the text there this command --no-fonts just like that and then apply and hit ok. This works great! :)
http://www.mail-archive.com/gimp-develo ... 12248.html
