- Tue Jan 15, 2008 3:46 pm
#258474
Hi JD,
here is another one for you.
Rhino crashed during the work with the material manager. I was just changing roughness values, when the crash happened.
attached I post the log_file. I also got a dump file, do you need this? It is about 11 MB size.
* Maxwell for Rhino 4
* Version: 1.6.1.0
* Session Log
* Date: 15.01.2008
* Time: 14:20:03.3905000
* File: file://C:\Dokumente und Einstellungen\Administrator\Anwendungsdaten\MaxwellDotNetSdk\Logs\session_log_1_15_2008_14_20_3.txt
* line 1: OnLoadPlugIn, _info, begin plugin-load
* line 2: OnLoadPlugIn, _info, Checking required paths
* line 3: CheckRequiredPaths, _info, Checking for MAXWELL_ROOT environment variable.
* line 4: CheckRequiredPaths, _info, MAXWELL_ROOT environment variable exists.
* line 5: CheckRequiredPaths, _info, Checking for Maxwell home directory.
* line 6: CheckRequiredPaths, _info, Maxwell home directory is located at: C:\Programme\Next Limit\Maxwell
* line 7: CheckRequiredPaths, _info, Checking for mxcl.exe.
* line 8: CheckRequiredPaths, _info, Maxwell mxcl.exe is located at: C:\Programme\Next Limit\Maxwell\mxcl.exe
* line 9: CheckRequiredPaths, _info, Checking for mxed.exe.
* line 10: CheckRequiredPaths, _info, Maxwell mxed.exe is located at: C:\Programme\Next Limit\Maxwell\mxed.exe
* line 11: CheckRequiredPaths, _info, Checking for mxst.exe.
* line 12: CheckRequiredPaths, _end, Maxwell mxst.exe is located at: C:\Programme\Next Limit\Maxwell\mxst.exe
* line 13: OnLoadPlugIn, _info, Creating EventWatcher
* line 14: OnLoadPlugIn, _info, Retrieving Material preview-size
* line 15: OnLoadPlugIn, _info, Creating Maxwell Scene
* line 16: OnLoadPlugIn, _info, Creating CommonFunctions
* line 17: OnLoadPlugIn, _info, Attaching mxCommonFunctions.pMaxwell
* line 18: OnLoadPlugIn, _info, Retreiving user-preferences
* line 19: OnLoadPlugIn, _info, Creating MaxwellDropTarget
* line 20: OnLoadPlugIn, _info, Registering MaxwellEventWatcher
* line 21: OnLoadPlugIn, _info, Enabling MaxwellEventWatcher
* line 22: OnLoadPlugIn, _info, Enabling camera auto-synchronization
* line 23: OnLoadPlugIn, _info, Enabling Scene events
* line 24: OnLoadPlugIn, _info, starting plugin update status thread
* line 25: OnLoadPlugIn, _end, Plugin-load finished successfully
* line 26: ReadCompleteDocument, _begin, reading complete document:
* line 27: set_CurrentDocumentDirectory, _exit, value = null; m_cd =
* line 28: ReadCompleteDocument, _end, finished reading complete document
* line 29: ReadDocument, _end, sucessfully read Maxwell data
* line 30: OnEndOpenDocument, _begin, filename: C:\_DATA\EXPO\NEU_rendering\M-R\2008-01-15_EXPO_M-R.3dm
* line 31: set_CurrentDocumentDirectory, _end, m_cd = C:\_DATA\EXPO\NEU_rendering\M-R
* line 32: OnEndOpenDocument, _end, filename: C:\_DATA\EXPO\NEU_rendering\M-R\2008-01-15_EXPO_M-R.3dm
* line 33: OnRenameView, _info, SelectedCamera = 'Perspektive_NW'
* line 34: OnRenameView, _info, SelectedCamera = 'Links'
* line 35: OnRenameView, _info, SelectedCamera = 'Rück'
* line 36: OnRenameView, _info, SelectedCamera = 'Drauf'
* line 37: OnRenameView, _info, SelectedCamera = 'Seite 1'
* line 38: OnSetActiveView, _info, SelectedCamera = 'Seite 1'
* line 39: OnRenameView, _info, SelectedCamera = 'Din A0'
* line 40: OnRenameView, _info, SelectedCamera = 'Seite 2'
* line 41: OnRenameView, _info, SelectedCamera = 'Din A1'
* line 42: OnRenameView, _info, SelectedCamera = 'Seite 3'
* line 43: OnRenameView, _info, SelectedCamera = 'Din A2'
* line 44: OnRenameView, _info, SelectedCamera = 'Seite 4'
* line 45: OnRenameView, _info, SelectedCamera = 'Din A1'
* line 46: OnRenameView, _info, SelectedCamera = 'Seite 5'
* line 47: OnRenameView, _info, SelectedCamera = 'Din A4'
* line 48: OnRenameView, _info, SelectedCamera = 'Seite 6'
* line 49: OnRenameView, _info, SelectedCamera = 'S+P PK'
* line 50: OnRenameView, _info, SelectedCamera = 'Seite 7'
* line 51: OnRenameView, _info, SelectedCamera = 'Din A4 Präse'
* line 52: OnSetActiveView, _info, SelectedCamera = 'Perspektive_NW'
* line 53: get_MaterialManager, _info, getting MaterialManager
* line 54: ShowMaterialManager(IWin32Window), _info, sz=942x617h, loc=103,262(virtual), pWnd=66070
* line 55: mxVersionChecker.CheckForUpdate(), _notify, checking for plugin updates...
* line 56: mxVersionChecker.CheckForUpdate(), _notify, the installed plugin version (1.6.1.0) is up-to-date.
* line 57: get_SceneManager, _info, getting SceneManager
* line 58: ShowSceneManager(IWin32Window), _info, sz=400x600h, loc=300,300(virtual), pWnd=66070
* line 59: WriteCompleteDocument, _begin, writing complete V1.6 document
* line 60: WriteCompleteDocument, _end, finished writing complete V1.6 document
* line 61: ShowSceneManager(IWin32Window), _info, sz=400x600h, loc=300,300(virtual), pWnd=66070
* line 62: Maxwell_Render, _notify, Maxwell_Render (RenderScene)
* line 63: PrintPathStatusReport, _info, -- BEGIN Path Status Report --
* line 64: PrintPathStatusReport, _info, Total number of Materials: 12
* line 65: PrintPathStatusReport, _info, No invalid paths found
* line 66: PrintPathStatusReport, _info, -- END Path Status Report --
* line 67: WriteMxs, _info, rendering camera: Perspektive_NW
* line 68: WriteMxs, _notify, Generating new MXS meshes, press CTRL+ALT+SHIFT to cancel
* line 69: meshing 0,0% completed
* line 70: meshing 10,0% completed
* line 71: meshing 20,0% completed
* line 72: meshing 30,0% completed
* line 73: meshing 39,9% completed
* line 74: meshing 49,9% completed
* line 75: meshing 59,9% completed
* line 76: meshing 69,9% completed
* line 77: meshing 79,9% completed
* line 78: meshing 89,9% completed
* line 79: meshing 99,9% completed
* line 80: listing errors - objects with no texture coordinates:
* line 81: mesh_object, ID = 4fdc4805-f496-48fd-aea7-21a4b8b5c60d
* line 82: mesh_object, ID = 28513034-0886-4d89-8c0c-fb6d36287181
* line 83: mesh_object, ID = 020f726f-c4a8-4c36-9ef6-b7f7493cfe07
* line 84: mesh_object, ID = bf9be562-c99a-4a7d-9a9b-8043be3cc4e9
* line 85: mesh_object, ID = 0cb84b4d-5746-4d4c-a939-91f9e75fec0e
* line 86: mesh_object, ID = 402eb090-94ca-4a5c-a2cf-5892997aca2f
* line 87: mesh_object, ID = 06d83ec8-9754-412d-8d67-a8c78f78bd83
* line 88: mesh_object, ID = 326ba24a-215d-4aa1-942b-9bfdc35956a6
* line 89: mesh_object, ID = 8f9bd25c-19fe-4e2b-ba37-8726aef8467e
* line 90: mesh_object, ID = 0bf3403e-5151-42e3-9d99-27a5499bd86a
* line 91: mesh_object, ID = 5d3e56bd-a0b0-4ce6-8144-03edf49bd954
* line 92: mesh_object, ID = e825cda4-05a8-46b1-a5ef-9d8924eaeb64
* line 93: mesh_object, ID = 57fa3a67-c942-492c-ba3b-458e203d8ac1
* line 94: mesh_object, ID = 3d209f58-c095-4516-8cdc-2c63be4bd958
* line 95: mesh_object, ID = efdfaef5-5ff2-4627-ab80-f41a1c2f85a4
* line 96: mesh_object, ID = 6871a278-47b9-4f6e-8ef7-8ca1d1795767
* line 97: mesh_object, ID = fd9ce64d-2c11-4717-9767-2c484200594e
* line 98: mesh_object, ID = 484b9192-0500-4329-bf72-3ba14e6dc13f
* line 99: mesh_object, ID = 924d979e-fb5c-4da6-9722-dd678bba4b97
* line 100: mesh_object, ID = 9f93d4f7-180c-453b-80a8-368187280efc
* line 101: mesh_object, ID = 1fe275c4-2d74-4df9-a972-4b1b29d91927
* line 102: mesh_object, ID = 283dc44b-b008-4aea-834f-c83bcf2a815f
* line 103: mesh_object, ID = df4c7bdc-2e99-4189-b510-2f326753aa2c
* line 104: mesh_object, ID = ff399eb6-3a70-45c7-9f38-dfea56b1c7a9
* line 105: mesh_object, ID = 023f5813-bc20-4749-bcbd-2e484cc56ed2
* line 106: errors were detected during meshing, the objects which generated these errors are now selected.
* line 107: if these objects are de-selected, and you wish to locate them again, highlight their ID in the
* line 108: Log Viewer, right-click, and choose 'Select Object'. Also see the 'SelId' command in Rhino help.
* line 109: ExportScene, _info, total export time: 00:00:07.2187500
* line 110: OnEndWriteMxs, _notify, ExportScene returned: True
* line 111: OnEndWriteMxs, _info, The .mxs was written successfully, the path was: [ C:\_DATA\EXPO\NEU_rendering\M-R\2008-01-15_M-R_02.mxs ]
* line 112: ShowMaterialManager(IWin32Window), _info, sz=942x617h, loc=103,262(virtual), pWnd=66070
* line 113: pMaxwell_SelectedMaterialChanged, _info, selected material = ETFE
* line 114: Exception report.
* line 115: Type: System.AccessViolationException
* line 116: Message: Es wurde versucht, im geschützten Speicher zu lesen oder zu schreiben. Dies ist häufig ein Hinweis darauf, dass anderer Speicher beschädigt ist.
* line 117: Source: Rhino_DotNet
* line 118: Has StackTrace: True
* line 119: BEGIN STACKTRACE: 'System.AccessViolationException'
* line 120: - bei CRhinoDoc.Regen(CRhinoDoc* )
* line 121: - bei RMA.Rhino.MRhinoDoc.Regen()
* line 122: - bei MaxwellPlugin.MaxwellPlugIn.DoRegen()
* line 123: - bei MaxwellPlugin.MaxwellPluginUtility.pSelectedMaterial_MaterialAppearanceChanged(Object sender, MaterialAppearanceChangedEventArgs e)
* line 124: END STACKTRACE: 'System.AccessViolationException'
* line 125: Has InnerException: False
* line 126: SendReportEmail, _info, permission to access smtp port obtained
* Version: 1.6.1.0
* Session Log
* Date: 15.01.2008
Intel Quadcore 6600 @ 2.88 GHz, 4GB RAM, XP64, rhino 4.0
MacBookPro T7800 @ 2.6 GHz, 4GB RAM, OSX + XP32, rhino 4.0
- By Mark Bell
- By Edward Leibnitz
