By Tung Ling Leung
#258251
Hi everyone,
In general I will set my SL at 25 but I will stop it when the SL reach around 18. Is that make sense to use noise reduction filter to enchance the rendering instead spend more time to wait?
Have someone try this before?
I wonder JD will you consider to add this feature in Maxwell? Does it possible and make sense?
Thanks!
Tony
#258252
Hi Tony,
I'm not sure I understood what you meant, but once MXCL is rendering the image, the plugin has no more control over the process. If there were to be any filters, they would be in MXCL, but I doubt the need for them since there are already lots of good post-processing softwares available.
Cheers,
JD
