By pwrdesign
#256683
Nice!
How many Emitter-sets?
And what resolution did you render out?
/ Patrik
By rosariogigliotta
#256684
9 emitter + enviroment
1024*768 px
intel pentium core 2 duo E 6600 2.4 GHZ
By pwrdesign
#256687
Is it ok if I do a ML animation for you of it? :)
By rosariogigliotta
#256688
wowww fantastic
if it serves to you I can supply mxi to you
excused my English
By pwrdesign
#256690
rosariogigliotta wrote:wowww fantastic
excused my English
No need :)
Here is a quick one from the stills!
http://www.aphox.org/GR.zip
/ Patrik
By pwrdesign
#256693
Tea_Bag wrote::shock: Great Renders rosariogigliotta!
@pwrdesign - What program did you use to create the still image animation and HOW? :) Nicely Done 8)
Open Adobe Premiere, import the still images, put them after each other in the timeline, add cross dissolve at the end and beginning on each image.
Place each image so the end-cross-dissolve on image one starts at the same time as start-cross-dissolve starts on image two.
If you should do it for real, you should save out each image in the following way:
Emitter 1
Emitter 1+2
Emitter 1+2+3
Emitter 1+2+3+4
And so on, that gives the most realistic result.
really cool renders Rosario... clap ! clap ! clap ! clap! (applause) 8)
Awesome, the dark one with Shrek and the bright one with daylight outside are my favourties.
