-  Mon Dec 10, 2007 12:19 am
					 #255516
							There is some sensitivity in SW 2008 (SP1) when applying Maxwell Materials that causes SW to crash.  I have tested this on two different XP32 machines both running SW2007 (SP5) and SW2008 (SP1) with the 1.6.0 plugin and can report that these actions seem to be causing somewhat frequent, albeit not every time, crashes of SW2008.  SW2007 does not seem to exhibit this sensitivity.
In both versions of SW however, I seem to be having difficulty in getting the materials to apply/display in any consistent manner. This is regardless the Enable/Disable Viewport Material setting; nor do other settings, (e.g. RealView, MultiMaterial) seem to have any effect.
Finally, I have one other materials related problem. I have been using the Arroway Concrete Textures and found that an SW part (just a simple single part) had grown from around 1 MB to approximately 70 MB in size after this material was applied. I tried changing the Material Editor's MXM Mode from Embedded to Referenced, but this did not change the file size. Finally, and certainly worst of all, all attempts to recover the file size by removing all materials have failed.
Any help and/or insight would be most appreciated.
Ken
Ken
 - By Forum Moderator
 - By Forum Moderator - By Andreas Hopf
 - By Andreas Hopf - By Blanchett
 - By Blanchett
