By .ST3.
#255239
Ok i'm not posting an issue i'm actually just posting a thank-you
thank-you to all the guys who worked on this version of maxwell and its plugin because you guys did a fantastic job!!
I know you get a hard time every now and again (or every 4 out of 5 posts in the cinema 4d section) but i have to say i find the new plugin a pleasure to work with and has stunning results!
Also Tyrone I have to say kudos to you for putting up with the whining that goes on here.....I wouldn't have your patience
On a last note - i have actually been put off checking this specific part of the maxwell forums even though i work with maxwell completely through c4d.....I think a lot of you guys have a very negative and ridiculous view and expectation on life as instead of looking at the good points about each release (of which there are a massive amount) you actually look for tiny faults and moan non stop about testing.....around 4 flaws and its not tested properly-are you joking me?
Also have you guys thought of maybe having constructive threads in here like in other areas where you discuss methods and don't give out?just a thought.....
anyway keep up the good work guys!
By Rochr
#255381
Well, i´m probably one of the "whiners" you´re referring to, but i actually concur with you about this release. I´ve found it to be a solid one.
Although i feel like i need to defend myself a little here. It´s kinda hard looking at a software from a positive side, when you´re having an average of about 30-40 crashes on each scene. And i´m not talking about those tiny faults you´ve mentioned, but unexplained hard crashes that bring down C4D as well half the times.
Then there are those path issues, hierarchy issues, deformer objects issues etc etc
Judging by the date you´ve joined, you haven´t been here for a long time. Perhaps you should try the above errors for about two years and we´ll see exactly how positive you would be. ;)
Anyway, enough about that.
Even though there are a few issues left, it´s still not that big of a problem, so, great work from everyone involved on this one!
