By juan
#255050
Hello,
We have released an update for the Form·Z 6.1 plug-in (Windows 32/64 and Mac), you can see more details here:
http://www.maxwellrender.com/forum/view ... hp?t=26555
Let us know if the issues you reported about the behavior of some buttons in osx and the sky rotation are fixed.
Apart from the bugs fixed, we have added compatibility with French languaje (thanks a lot Jean-Luc!!), the resource file is included with the package. If you set French as the active language in FormZ, you will see the text fields of the plugin in French.
Thanks!
Juan
By dkessler
#255113
I can't get the updated Maxwell Plug-in (win32) to show up in the menu or surface style parameters. The old plugin works fine. If I drag that folder out of the plug-in directory and put the new one in, Maxwell doesn't show up.
By juan
#255187
Hi dkessler,
Are you using FormZ 6.1.x or 6.5.x? Please download the plugin again, we have noticed that the file size of the x32 plugin in the server is a bit different to the one we built.
Do you have the resources file (.fzr) in the same folder than maxwellrender.fzp ?
Do you have other versions of the plugin under the FormZ plugins folder?
Thanks,
Juan
By dkessler
#255231
Juan,
I'm using formZ 6.5.4. I tried downloading the plugin from both mirrors and got the same problem. All I did was unzip the download and place the entire folder in my plugins folder. I then zipped up the old plugin folder to ensure there wasn't a conflict.
Apparently, I'm not the only one having this problem:
http://www.formz.com/forum2/messages/16 ... 1197031075
Dan
By dkessler
#255240
Juan,
I just noticed that the plugins were updated as of today Dec 07. Now it is working!
Thanks,
Dan
