By alexh
#254400
Hello
I create a simple scene to see how works the animation now.
I did:
Check the anim box
Start=1
end= 5
I press Render.
C4d voxeled the 5 images seq. (I filled in the destination folder)
Maxwell render the first picture fine, BUT when maxwell shift to the second one I get this message:
ERROR! - "objet "X"has triangle without material"
Render Failed
Could you have a look on my scene please.
Here is the http://dl.free.fr/jOUpxkLlK/studioeclairemax.zip
thanks
By Becco_UK
#254412
alexh: I ran your scene on my windows XP system and the frames rendered ok. I opened the saved images in Quicktime and the animation worked. All I done to your scene was change the directory to my project folder.
I should mention I use Maxwell 1.6 with the old Cinema plugin. So it really needs someone to come along and try this with the new plugin.
By Becco_UK
#254414
Just compared the . mxs files - yours are each 404KB as opposed to my 398KB ones - but this may be to using a different Cinema plugin.
By jc4d
#254415
Hi alexh, I think you find a bug the materials are not saved after the frame 1, i opened the mxs in studio and that material is not saved, only in the frame 1 this is in C4D 10.111 Win Xp pro, and i made the same test in C4D R9.6 and it´s worst i get a error message that say MXS file does not exist, and i open the mxs´s in studio and the only frame that have the material is the first frame. :?.
If anyone can reconfirm this.
Cheers
JC
