By Renato Lemus
#253251
Hi: this started as a small excercise using 2,000 instanced trees (about 200 million polygons) that turned out into this image.
Render time was about 2 hours 30m.
Dual Xeon 3.2GHZ dualcore, 4gb DDRAM.
By Calico Jack
#253260
By numerobis
#253281
:shock:
YESSSSSS!!!! INSTANCING!!! :mrgreen:
...and great image! :D
lovely image Renato, so untypical for Maxwell.
By Leonardo
#253317
I only see like 10 trees :lol:
you must be mistaken!! maxwell can't do that!.... or can it? :shock:
Very nice :)
By Renato Lemus
#253390
Thanks all for your coments. :D
Leonardo: Sure, maxwell can render even more!!. More than 3dsmax can handle, I had to use cloned boxes as placeholders with an xref (the tree) attached.
You're right, this image shows only a few trees, but I rendered an aerial view, with all the trees in it, but it is not as interesting as this one. If you want to see the real power of maxwell instances check an image by Tom who rendered thousands of Buddhas.
By Renato Lemus
#253613
Bubbaloo wrote:How about adding some displaced grass?
I thought about that...but most of the grass was very far, so it would be a waste of processing time, but I'll give it a try, thanks.
