By x_site
#253016
this is a SU feature... don't think you can do it with max but you can export textures etc, from SU...
By JTB
#253069
http://area.autodesk.com
There is a nice photomatch tutorial there
By wr1nkles
#256744
Hi Def4d, I have used 3D max for accurate photomatching for such things like appeals and cases that need a high level of accuracy. The 3D max photo match tool is as good as any other however the matching process is usually only as good as the data that you have taken in your survey and reproduced in you model.
If you need a hand, pm me and id be sure to point you in the right direction,
regards,
Nik
