By Holger Schoemann
#252141
hi there,
be not here for a long time ......
.....today I wanna give mw a new try.
after installing and fixing the pathes for winxp it runs fine.
but when i load a material from the material library, mw says
that the path to some files, r2 for example, couldn´t be found.
when setting it by hand and leaving the mm, the path is again false.
i´m running german xp with the path c:/programme* instead of
c:/program files/*
have I to load each material and save it with the right path???
By beatriz
#252208
hi!
it should work with no problems.
Please make sure you have the files actually.
and while we have a look at it, you could try to make a "program files" folder just to put the material database there so that you don't have to reassign paths manually.
Are you on 32 or 64 bits?
Thanks,
By Holger Schoemann
#252218
hi!
running here on 32 bit.
