By Martin_Mei
#250815
I recently installed SW2008 and the Maxwell pluginn doesn´t work. I tried deleeting and reinstaling it, but the Maxwell icons in SW still does not apear to be active. When i try to save a file as MXS i get this error:
sldexitapp.exe - unable to locate Component
This aplication has failed to start bacause MFC80U.DLL was not found. Re instaling the aplication may fix this problem.
Does anyone know how to fix this problem.
Im running win XP 32
#252055
Hi Martin,
Please try the new plugin...although it's compatible with SW2007 SP3.1+, I'm mostly running it on SW2008 during development - so it should be working fine.
Cheers,
JD
