By bjorn.syse
#246686
Hi
I've downloaded Tom's ice material from http://mxmgallery.maxwellrender.com/sea ... search=ice
... But I can't get it to work as showed. I've loaded up the standard material scene, and added ice to the TEST OBJECT. but the results I'm getting are really even not close.
Ok, It's small, but something should be showing at SL 15 or am I wrong?
Have I missed something? damn.. I must have :)
- Björn
Thanks for making me aware of this. Probably this material has been affected by a small change/fix to material SDK or I've uploaded a wrong copy. But no problem, it's now fixed and uploaded. In order to have same quality, I guess you'd need to render up to SL20 or 21.
By bjorn.syse
#246760
Thanks Tom, I'll try it out. I'll see whichever sample level my current laptop can achieve in a reasonable time
By bjorn.syse
#247887
So, still look kinda the same. But you're telling me this will start looking like your ice above SL 20?
Regards,
- Björn
Bjorn, .. don't you know ? Tom's ice is what ice looks like at -273K. :lol:
Yeah ... something wrong with that one. :)
By bjorn.syse
#247954
haha, right. Need to get some extra cooling for my laptop then.. :)
Here's the "ice" at SL 21
It looks like this material is affected by a known bug with Subsurface vs. attenuation. Try removing Subsurface layer, increasing attenuation and adding Subsurface back with same parameters.
By bjorn.syse
#247970
ok, I'll try that.
Increasing attenuation on the Frozen layer only? then one that had the subsurface?
By how much you reckon? it's at 2 cm now...
