By mitchrichie
#246632
I'm using the Maxwell plug in for maya 8.5 on a intel mac pro.
When I render a single frame it works fine, but when I try to render out an animation, via batch render image sequence, I get something really strange on every image in the sequence.
See links below:
Messed up image in batch render sequence:
www.ragusmedia.com/test1.jpg
Normal single render:
www.ragusmedia.com/test2.jpg
Any ideas why?
Also, If I export as a MXS for animation and then render the animation outside of Maya, I get an error because maxwell can't load the texture maps. As they are all in the same directory as the MXS and all on the same local machine, I can't understand why it has this problem.
By Jorge Alix
#246782
It seems textures are not loaded correctlly, try next:
-Export sequence to MXS
-Use Maxwell render Network and set the bitmap path whereever you have the textures.
Be sure all textures were in the same path.
