By SaT
#244548
I wonder if the dof preview in LightWave 9.2 and later correspond to the dof in Maxwell Render? Does anyone know from experience? Thanks.
By hdesbois
#244563
I've made tests a long time ago with Fprime. DOF was quite the same. I did not like so much LW native DOF (I mean 7.5 and 8.x, did not experimented with 9.x DOF), so I can't tell.
H.
By SaT
#244650
When FPrime DOF seems to be the same, then it should be the same like LightWave's DOF preview.
Thanks. :)
By hdesbois
#244673
SaT wrote:When FPrime DOF seems to be the same, then it should be the same like LightWave's DOF preview.
Thanks. :)
There is a limitation with Fprime, though: the frame height setting does not affect DOF: it's always matching a 24 mm frame height (not tested with fprime 3.x). AFAIK, Maxwell lightwave plugin also matches a 24 mm frame height DOF, even if you can change that in studio. So, unless if you have a good reason to do otherwise, it's better to stick to 24 mm frame height. If you want an exact match, the picture size (in pixels) should be homothetic of 36*24 (for instance, 900x600).
H.
By SaT
#244864
Thanks hdesbois for the extra information.
