- Mon Sep 10, 2007 11:42 pm
#242829
Dual core, 4 GB ram, dual display NVIDIA Geforce 8800GTS, Vista 32 Ultimate, 3dsmax8
Max slows down significantly when maxwell materials are applied to objects. When I load a max scene (with maxwell renderer assigned and maxwell materials assigned), the viewport performance is really slow when in shaded mode. Switching to wireframe provides a 1000% boost.
Vray and scanline scenes can be navigated smoothly with 8800GTS even if they contain millions of polygons. I even tried loading a maxwell max file, and without assigning a new render, I selected everything in the scene and assigned a standard material. The slowdown dissapeared instantly.
I tried messing with the viewport configuration, switching from DirectX to OpenGl and vice versa, changing settings, moving the max window to the adjacent display, deactivating the dual display mode, but to no avail.
I searched the forum, and found out some similar problems but no solutions. So I am trying to bring this up again.
I forgot to mention that I updated with the latest nvidia forceware
- By Mark Bell
- By Mike Amos 20251018183343
