So you draw a render region in viewport, let it render, stop it, drag another render region....and what happens? Not sure what you mean by 'reboot mxs'.
By leoA4D
#237228
Hey Mihai.
I select a region (MWR leaves a gray box over the selected area), let it render, click in the viewport to end the render. Repeat these steps for the nearly identical area and it renders. I repeat these steps for a third time for the nearly identical area and it does not render. I then quit the MXStudio app, restart and repeat these steps.
This has happened several times and I have not had success with rendering after the second render region.
