I'm somewhat in need of this to help speed up workflow and to reduce re-rendering of the same file.
Rendering at 2000x1500 for multilight, but when exporting as frames, there is no control over resolution. I don't need a 2000x1500 animation but one at 800x600 for example.
Please could the render options resolution have an effect on multilight exports.
Current workflow seems to require re-rendering for a ml animation at required resolution. So one ml at 2000x1500 for the render and one at 800x600 for the animation, which means extra long rendering times. Should be able to do this in one go using MXCL.
Thankyou,
But when you render the ml animatin, you export individual frames, which you can then batch resize to the size you want. Will be faster than re-rendering again. Although an option to choose ml resolution in MXCL will be a good thing for the future.
Mihai wrote:But when you render the ml animatin, you export individual frames, which you can then batch resize to the size you want. Will be faster than re-rendering again.
This is what I do already through Blender's sequencer. I'm just trying to reduce the number of processes in my workflow.
Mihai wrote:Although an option to choose ml resolution in MXCL will be a good thing for the future.
Please. :)
Thanks,
did you tried luxCore?
