- Tue Jul 10, 2007 5:39 am
#236741
I installed the XSI addon when it first came out and rendered out some tests and then went off to explore ZBrush 3. Now I've come back and can't seem to get XSI to communicate with MR at all. I can't edit Maxwell materials in XSI and I can't send scenes to MR to be rendered. I get nothing from the edit button on the Maxwell material node and I get a red border and an abort when I try to render a pass. I get the same behavior with scenes that had rendered before and with brand new scenes. I can export an MXS and it will render fine. So I'm assuming I have some sort of path problem, though I haven't knowingly changed anything since my original install. I have uninstalled and reinstalled the addon and the spdl, with no effect. I don't know if this means anything, but all I have in the MR custom preferences is a box to enable automatic update. I have MR installed as a user addon, and there aren't any odd workgroup issues. Help or advice much appreciated.
