- Wed Jun 27, 2007 7:04 pm
#234789
I have an MXM I used in a project in 1.1. The MXM worked fine. I updated to 1.5 and started having an odd problem that when applied the MXM comes out much bigger than it was originally. I said forget it, I'll re-create it (about 20 seconds, no big deal). I recreated it and appplied it to the same surface. Again, it came out huge. Now for the really odd part. Even though I began from scratch, made a new MXM and saved it as a different name, when I load it it still shows the OLD preview render and has the same size problem. I took the original object (Lightwave LWO) stripped the old UV map, saved it under a different name, made a new map, recreated the material again, and have all the same problems! And, the preview shows the old MXM! This is even after making an entirely new MXM and doing a new preview render.
I guess if I made a new MXM, re-created the old LWO as a new one and saved everything as differnet file names, why is it remotely possible that I still see the old preview and have the same problem! I'm way passed confused at this point...
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!" but "That's funny ..."
Isaac Asimov
Isaac Asimov
- By Matteo Villa
