By JTB
#233555
I have a big problem with mat. browser, maybe it is not Maxwell's fault. I downloaded the big 1500mats library and when I open the mat. browser from inside MAX, it crashes, without any errors... it just disappears from the screen!!!
This happens all the time. Can it be because I have all the materials in one directory and the preview is a heavy job? I don't think so because I am working on a quad with 4Gb Ram.
Has anyone experienced this?
By JTB
#233665
Nobody else?
I can't work, MAX always crashes without even a message!
Can it be because I have 1500 mats in one folder? (I use one folder for mats, one for textures)
By Mihnea Balta
#233706
There's a memory leak in the code that handles material previews. Max will run out of memory if you try to preview 1500 materials. It will be fixed in the next version.
By JTB
#234312
Mihnea Balta wrote:There's a memory leak in the code that handles material previews. Max will run out of memory if you try to preview 1500 materials. It will be fixed in the next version.
OK,thanks, I just saw your answer...
