But the materials do not hold the projector info, the objects themselves have the UV info?
By giacob
#233185
i import tne mxm and it automatically assign the projector... what should i do.?..
i frankly cant undertsand anymore what is the relationship between the lw material editor and the maxwell shader material editor... i mean: the value set on lw material editor have any influence on maxwell material editor or the values set in this latter overide the value of the lw material editor?
By giacob
#233186
besides Mihai tell me how i can assign the projector befor importing the materials.. seems impossible to me
I'm not familiar with the LW plugin, but do your objects already have UVs applied to them, before you apply the mxm to them?
By giacob
#233188
no dot have if i use the standard projector (cubic, planar, spherical etc) could have if i use a Uvmap ..
By giacob
#233338
it seems to me that the mxm material editor dont take into account the value of lw material editor ( whic is also logical) so it is impossible assigning the uvmap before importing the material
By Mihnea Balta
#233352
When importing a MXM file, textures are set up using the default LW projection mode, which happens to be planar. We could change it to cubic if you think it covers more cases, but I say that in the end you need to go and set up projectors or UV maps anyway.
MXM files contain the index of the projector for each texture. This is meaningless in Lightwave so this information is not imported. The fact that, for example, the roughness texture uses projector number 2 doesn't translate in any way in Lightwave.
When exporting a material as a MXM file, some projector numbers are set, but they are again meaningless, because the order that those indexes reference depends on the object.
By giacob
#233354
the fact is that the cubic projector avoids the " not enough material etc... etc.." error message and the consequent stop of the render ..
a think that cubic cover much more cases and even if in some cases must be changed it avoids the stop of the render
By Mihnea Balta
#233355
The "not enough UV channels" bug is unrelated to this. We will fix it so there won't be a need for a workaround using a cubic projector. Anyway, there's no difference between how cubic projectors are handled and planar projectors, so it's strange that you say it fixes the problem.
By giacob
#233361
u r right ....i remembered in the past having some problem with planar projector but i was misremebering.....
By lopatam
#234203
I use only Uv maps.I've to reassign every time my uv maps. I can't save my mxm with the uv,It's boring to reassign on new material the uv map ,in the 1.1 when i save my mxm it retains the uv map as the projection. .I named all my uv "texture" .
I think 1.5 is great but the lw plug-in in is missing some simple features .
By lopatam
#234231
instead of loading the mxm now I use the surface preset from Lw ,it works until you use always the same name for all the UV maps .
