- Mon Jun 04, 2007 5:03 pm
#230976
Hey huys I am running a Mac Intel Eight Core with Maya 8.5 and getting a successful render note inthe console but NO image I mean no black scrren no image nadda.
This does not happen on other intel machines or other non intel macs I have tried it on.
Any ideas?
===================== New session opened at 04/June/2007 07:56:24 =====
MAXWELL RENDER (M~R). Engine version Maxwell Render 1.5.0.2
(C) 2004-2007. Licensed to Next Limit Technologies
/Applications/Maxwell/mxcl.app/Contents/MacOS/mxcl -d -seed:0 -mxs:/tmp/mxslTVNVl
>> Note: Ignored obsolete 'seed' field
[04/June/2007 07:56:24] Reading MXS:/tmp/mxslTVNVl
[04/June/2007 07:56:24] MXS file read successfully
Geometry:
- Num Meshes: 185
- Num Triangles: 601708
- Num Vertexes: 304895
- Num Normals: 283826
Bitmaps:
. Num Bitmaps: 0
Render settings:
- render core : RS1
- render version : Maxwell Render 1.5.0.2
- desired rendering time : 8h20m00s
- desired sampling level : 100
- render resolution : 1600 x 1200
- using 8 threads
- illumination layers:
. . direct layer: true
. . indirect layer: true
. . direct caustic reflection layer: true
. . direct caustic refraction layer: true
. . indirect caustic reflection layer: true
. . indirect caustic refraction layer: true
[04/June/2007 07:56:24] Checking Data
[04/June/2007 07:56:24] Loading Bitmaps & Preprocessing Data
[04/June/2007 07:56:25] Start Voxelization
[04/June/2007 07:56:38] End of voxelization
[04/June/2007 07:56:39] Start Rendering
[04/June/2007 07:56:39] Render finished succesfully
Any ideas?
Geometry:
- Num Meshes: 185
Bitmaps:
. Num Bitmaps: 0
Render settings:
- render core : RS1
- using 8 threads
- By Matteo Villa
