By zoppo
#230064
you can always click "display" and it shows the current merged sl along with the current picture.
By b-kandor
#230068
Where does it show the 'merged sl', I just see the individual nodes sl listed?
When you click the tab of merged image you can see it below.
By b-kandor
#230118
Maybe I mis-understand.
The merged image isn't available till you stop the coop right? If you mean the display tabs created when you select a node and click the display button, those tabs show just the current node's sl level not the predicted merged sl.
Select the tree (not the nodes) and hit display. ;)
