- Mon May 28, 2007 10:01 pm
#229134
for "Still same Problem by Maxwell 1.5 -- Can't open moved mxs in a other folder (destination) .." see the link moved mxs
ITS ALSO POSSIBLE THAT THIS ISSUE IS A PROBLEM FOR WINDOWS-USERS WITH GERMAN-CONFIGURATION!
Shortly the problem description:
The problem is not the file-access-right, which i thougt first. No it's the umlauts in German. We use in german sometimes Ä,ä,Ü,ü,Ö,ö.
> If the file name contais one of this Letter (Ä,ä,Ü,ü,Ö,ö,.....) the mxs, mxi can't open.
> If also a mxs or mxi without the Letters (Ä,ä,Ü,ü,Ö,ö,.....) is in a Folder or Subfolder, which is named with some ore one Letter of (Ä,ä,Ü,ü,Ö,ö,.....), the mxm can't open.
Maybee somebody can make a Test on a windows System with Geraman umlauts (ÄÖÜäöü) in the Filename or Folder.
Greetings Michel
Greetings Michel
- By Matteo Villa
