By trofaster
#228924
I’m having trouble with opening my old scenes, made on m~r 1.1 with an pre 1.079 maxplug. First I merge everything to a new scene except the Camera, to avoid that bug – now there are no working materials (the exporter shows the could not translate the object “xx”s material “xx”). I then save the scene with the new camera, and reopens it. Then I get the dialogue that asks me whether I want to use instanced or referenced materials. I choose one (doesn’t seem to matter if I choose one or the other), and start working with the scene. Everything works fine, until I try saving, and then max crashes. I’ve tried merging everything from the scene into a new one – same problem. I’ve tried “save as” & “save a copy” with the same result. Any idea on this?
By Bogdan Coroi
#229027
Confirmed only on max9. On max8 seems to work OK.
We'll try to figure it out, and if so, the fix will be available in the next update.
