By juan
#228875
Hello bertilh,
which version of formZ are you using? I assume you are working with formZ 6.1 or newer and the latest version of the plugin. I've never seen this message before. Does it happen even in very simple scenes? (for instance create a cube with the default surface style and purge unused materials, does it happen?)
Regards,
Juan
By mojo
#229167
i had this masaage too when rendering one project. FInally I copied one layer after the other into a new file. I am not sure, another thing i did was to delete the saved viewpoints and to recreate them in the new file.After these steps the message dissapeared...
win 2000
formz 6.1
