By Bogdan Coroi
#228045
Try this command in your command prompt:
Code: Select all
echo %MAXWELL_ROOT%
and make sure it points to the correct Maxwell 1.5 path.
Also, you might want to remap the extension to the new mxed.exe, since Windows Explorer is not that smart. The simplest way to do it is by reseting the current file type association. Open an Explorer instance, Tool Menu->Folder Options...->File Types Tab. Look for the .mxm file extension and delete it. Close the dialog. Double click again on the .mxm file and browse to your new mxed.exe file.
Hope it helps.
By Nuno Faria
#228053
Bogdan Coroi wrote:Try this command in your command prompt:
Code: Select all
echo %MAXWELL_ROOT%
Hope it helps.
I did exactly what you said, and when i try to double click on the material (mxm) it pop's up an error dialog box saying "The Parameter is Incorrect"
By JCAddy
#228085
Code: Select all
echo %MAXWELL_ROOT%
Hope it helps.
By Mihnea Balta
#228256
Open Explorer and go to Tools -> Folder Options -> File Types and find "MXM" in the list. Click "Advanced". You should see an action called something like "Open with Material Editor". Make sure it's the default, select it and click "Edit". In the "Application used to perform this action" make sure you have the following string:
Code: Select all
"C:\Program Files\Next Limit\Maxwell\mxed.exe" -mxm:"%1"
Of course, replace the path above with the path where you have 1.5 installed. Don't forget the quotes around %1 and don't put any spaces before or after the colon.
Anyway, this is not a Max plug-in issue. :)
By michaelplogue
#228275
Mihnea Balta wrote:Anyway, this is not a Max plug-in issue. :)
Perhaps then it's a Max Plug-in Installation issue... :wink:
By Mihnea Balta
#228276
It's a Maxwell installation issue. ;)
By michaelplogue
#228302
Mihnea Balta wrote:It's a Maxwell installation issue. ;)
My bad! :P :P
By LesliePere
#228583
%MAXWELL_ROOT% is correct, and the file type association is correct to every detail, yet it's still not opening the mat editor after double clicking the mxm file type.
#228646
Hi Leslie, try this:
1) open Explorer, browse to a folder containing .mxm files
2) right-click any .mxm file
3) click 'Open With'
4) click 'Choose Program'
5) check the checkbox near the bottom of the window - 'Always use the selected program to open this kind of file'
6) browse your Maxwell directory, choose mxed.exe
7) click OK
Let me know if it works,
JD
By LesliePere
#228856
No it doesn't. But thanks for the suggestion.
PS: I've actually done that a couple of times before, too.
By LesliePere
#228857
Ok, I fixed it. Oddly, as Mihnea suggested a few threads below:
Did not work. That's what I originally had. I had to remove the "-mxm:"%1"" from the end like this:
Now this works. Don't ask me why...
