By wagurto
#227777
1.5 plug ins have an annoying pop up windows everytime I load my material editor or change/apply a material on my scene. Also the process seems to be much more slow than before.
By wagurto
#227787
it gives you information of each indivudual render time of each material on the browser. An every single time I apply a material on my scene.
By Mihnea Balta
#227790
Right click a slot in the material editor, choose options and check "Manual Update". Does this help?
Which version of Max are you using?
By numerobis
#227838
it happens with the manual update too. a console window pops up and closes when the update is finished...
(xp64 - max8sp3 - maxwell 64bit)
By Mihnea Balta
#227841
The window that pops up when you make a material preview is MXCL which is rendering the preview. We can hide it but Max is frozen until the preview is done anyway, at least this way you can see that it's doing something.
However, this shouldn't happen when you drag a material in the scene. It should only happen when you click "update preview" or use the floating preview window. Are you sure it's the same window when dragging the material into the scene?
By JTB
#227844
Mihnea Balta wrote:...Max is frozen until the preview is done anyway, at least this way you can see that it's doing something.
I agree, it is not annoying.
Yes, we see it only when updating preview.
By numerobis
#227865
yes, only when updating the preview.
