By Bogdan Coroi
#227603
What do you mean by "it fails"? Could you please give us more details?
By arch4d
#227604
does the second mxs in the render queue fail ?
that would be exactly as in cooperative mode on our network...
By bodebodebode
#230968
I have some similiar problem here.
3D max crashes every time i choose to render an animation, but if i select one of its frame and render it alone, it goes well.
Please NL we need some advise on this because rendering lots of frames manually is sacrifice.
By Maxer
#230978
Juan got back with me and said that the reason my animations were failing was because I was saving the output images with number sequences instead of giving them an alphabetical name. I haven't tested this because I had to go back to V1.1 in order to be able to render out my animation after loosing a week trying to figure out this problem. I hope this helps you.
By bodebodebode
#231066
Nice, Maxer.
This trigger rendering !!
No more crashing, but i still havent´s fired up the animation render, later i will post results.
Anyway, thanks and good luck on your animation !
By andrebaros
#231747
I also found that Network Rendering would crash on rendering a frame range if the output files already existed. It seamed to have trouble over writing existing images because after I deleted out those files it worked.
Correction: It worked once, but today I had the same problem and tried the same solution and it didn't work.
