By adri
#223830
Hi
I've set up a layer mask/weight map which I'm trying to put onto a disc to create a dial. If I have tiling switched off then I'm getting stretching of the text in the weight map. turn on tiling in the C4D material tag and it goes away.
Is there any way I can turn off tiling and not get this stretching?
TIA
Adri
By mmhnemo
#223905
Can you show the corresponding UV Map?
