- Fri Jan 26, 2007 8:33 am
#206786
Anyone have any ideas?
The rod mesh was imported from an STL file from Unigraphics and are exact copies of each other.
The Teapots are used as control objects creatred in MAX9.
The rods and teapots are all using a standard aluminum material created using the 3Ds MAX 9 Maxwell plugin. The ONLY diffrence in materials is the upper teapot and rod do not have a bump map. The lower teapot and rod have the bumpmap turned on.
So,
Why is the lower Rod with the bumpmap black?
If the mesh is the problem, why is the Rod without the bumpmap OK?
If there is a material problem (UV maps etc.) the why is the lower (Bumpmap) teapot OK?
Thanks for the help.
Dan
So,
Dan
"Art is never finished, only abandoned." -Leonardo da Vinci-
- By Matteo Villa
