By xmood
#202510
hi all
here is a simple scene file http://depositfiles.com/files/476484
when i click render .. it give me " complete " but there is no rendering
some thimes that when i use alot of mxm in the scene , the default mxm or new one .
maybe its about the path or someone can tell me why
thanx
By Boris Ulzibat
#202512
xmood wrote:hi all
thanx
Really simple!
Assign a material (or just a texture tag) to the object with material "WOOD".
Drag the tag icon into the texture field of maxwell custom MXM tag.
Hit render!
If there are such errors in the future, it is a good idea to look in the
"console" tab of MXCL - the reasons and the errors are listed there!
By xmood
#202514
GOOD ANSWER :)
thanx Russia man ...
one more qustion ... why the sun not workin here ?
By Boris Ulzibat
#202516
xmood wrote:GOOD ANSWER :)
Thank you!
About the sun issue - try changing the GMT offset to something different from 100 (which is the default) - it is a rather strange value, which seems do disable the sun.
It is quite easy and rawarding to spend some time on setting up the expression which links the Maxwell Physical sky with the Cinema's default sky.
This topic is explained in this section of forum. You need to make some adjustents to Cinema sky as well. but as a result - you get a realtime correct preview of what you'll get in your render.
AFAIR you must disable Daylight savings in Cinema's sky, maybe something else too.
Glad if i was of some help!
By xmood
#202518
thanx m8
its works now
